1 - 2 of 2 Posts
Hello, i recently bought a 11 FA5 SI, with hondata flashpro and K&N SRI. The previous owner told me it has a tune but i think is just a base map. I change a bit the fuel tables because it was lean. Now i hit AFT 14.6 in idle and in cruising and 12.9 / 13.5 in WOT. i hope you can see my datalog and calibration maybe you can see deeper .
Thank you
Some cars run rich, like my n/a motor goes into 10's at full power, while others will be where you are on the lean side.
Have a pro look at Datalog of 30 min of street driving, and a 3rd gear wide open throttle pull to red line.
Or get a dyno tune...either way will tell if your engine is performing optimally, and give you more power.
1 - 2 of 2 Posts
