Hello All,
My 2008 Civic Si Sedan front passenger spring snap and I need a replacement strut. I have a set from 2014 Si sedan sitting in my garage. So, I just install it today. I am aware that the mounting holes are bigger in 9th gen and there is a sway bar link hole which we don't use in 8th gen. Other than this, it should be a straight bolt on.
Once I have everything installed, I notice that the wheel knuckle is not straight, it is protruding out. What could be the problem? Is it the 9th gen strut is not compatible? Might be holes position is off. But I have read someone did that with no issue. I am really have no idea.
Since then, I have been looking for 8th gen Si sedan but have a hard time finding one. I can see a lot of choices for 8th gen Si coupe but not for sedan. Can I order the coupe and put it on sedan? By the way, I am from Toronto, Canada. So, parts are not abundant as compare to US.
Thanks in advance.
Thanks in advance.
