1 - 9 of 9 Posts
Is there any reason why headlights designed for 8th gen 2dr civic would not fit the 8th gen 2dr civic Si? Just curious because i saw a listing for headlights that stated they were for 06, 07, & 08 2dr honda civics but would not fit the Si. Doesn't make sense to me, but I want to be sure before i go dropping $200 on headlights anytime soon. Cheers!
if you are looking for headlights on ebay or something. they most often times omit all the trims because there is not enough room on the title for them to display them all
it was my understanding that the only differences between the si & the r18 were as follows....
spoilers
grilles
engines (including transmissions for manuals)
badging
sound system
suspension
sway bar
wheels
everything else, spec wise, should be the same
Way to go off track...
The headlights should fit, as the only difference is the amber ring around the DRL/Highs.
correct.
Si coupes have amber rings around the lights.
Other coupes do not. Makes it slightly easier to spot an Si from the front (besides the Si badge)
1 - 9 of 9 Posts
