1 - 1 of 1 Posts
If u plan on dueing some audio in ur car u should really upgrade all the factory enginge grounds. all u have to do is unbolt all the 8ga wiring (battery to chassis, chassis to tranny, tranny to engine block, and the block to the radiator area. and the alt..) I think these r the ones... not sure, U gotta check..
Then u use 4ga and tie each of the ground points back to the battery individually and ur set..
Better voltage flow, less resistance, less likely to put strain on ur engine/electrical system and it makes ur auto tranny shift easier/smoother and has to potential to slightly increase mpg (.5-1mpg)
Just go to ur local audio shop/online and order some 4 ga (measure it out so u know how much u need) and get some 4 ga gold ring terminals
1 - 1 of 1 Posts
