I have a 2006 - 20011 Honda civic. Problem is that the air temperature sensor is not showing any values. I have found the problem which is that the ambient air temperature sensor is not getting grounded. What I did was to cut off the ground to the cable and wire it to a new ground. When turning the ignition on I was getting proper temperature readings but the car will crank but not start. When removing the ground from the temp sensor it starts again. Any thoughts??
