1 - 2 of 2 Posts
I need help with my car. Because whenever i put my charger port on the power outlet my car be making sound like hissing whenever I stepped on gas. But whenever i dont plug my charger adapter it doesnt make a hissing sound when I step on gas
aftermarket or factory stereo? You're correct that its an electrical issue, you will likely be able to fix it by running a new ground wire from the 12volt socket. This issue stems from a common ground, the car is obviously a common ground for everything touching bare metal but this will help by separating the ground from your stereo and the ground from your 12volt socket.
1 - 2 of 2 Posts
