1 - 8 of 8 Posts
Hi all, i have a strange issue with my 8th gen manual 1.8. first thing in the morning when i reverse up my drive it makes a grinding noise with abit of vibration, my first thoughts was its the clutch but it doesnt slip in any forward gears so could it possibly be the lower rear engine mount that is behind the engine near the gearbox? The odd thing is it only happens first thing in the morning, any help is greatly appreciated
I have a confirmed bad passenger mount in my Tsx and it does the reverse grind on the first go even if I pump the clutch and especially when its cold outside. I think its something misaligned.
if you select 1st gear and then you go to reverse? do you still hit grind? funny I never hit grind on reverse. I do grind on 2nd when is super cold. 2009 si with 106k miles, Last, when did you replace tranny fluid last ?
1 - 8 of 8 Posts
