1 - 9 of 9 Posts
Ok i found a thread on clubrsx where the guy bought the cams when to put them in and they're about a millimeter too short and don't fit correctly.
Doubt i'll be buying these.
I don't think it's greddy's mistake. They have to test this cams to a certain motor, how can they test it if it won't fit. The guy probably ordered the wrong one.
dude the guy wasn't a dumbass. It was 100% the correct part number stamped onto the end of the cam.
Greddy's fault. The thread never seemed to get a resolution post, so whatever.
Discussion Starter · #6 ·
It's possible that there's a mixed up for the part #
But no way that the cams won't fit.
I have a feeling these are VERY mild and will not return what a different aftermarket cam would. I am assuming that is how they can get away with not having to upgrade the valvetrain, springs, retainers, etc. They must not increase lift that much.
I wonder how much different these are to the specs on a TSX since a lot of people say that you can use their cams and get a little more power out of our cars.
it sounds like it has more aggressive non-vtec lobes (claiming more torque and what not across the power band), but probably not much if any bigger vtec lobes
regardless, it's impossible to tell without lift/duration measurements.
1 - 9 of 9 Posts
