Time and a fat fat fat fat fat wallet lol
no people have definitely made a bit over 300 going NA but it is TOUGH! Every high HP NA build ive seen is a k24 block with a k20z3 head and have basically every single internal part replaced. most are also ported/sleeved up to 2.5L.I think highest from a member here right now is 275ish whp.
You clearly haven't checked the Supercharging forum recently. 350 is an easily obtainable number over there now.even supercharged its tough to get 300whp
Yea 300 is a fairly "easy" place to start for supers. Super plus decent bolt ons will make you 300. On NA you need absolutely every part of your engine working in perfect harmony To make 300.even supercharged its tough to get 300whp
sure, ive seen I/H/E with a super a LOT. dont want to run a huge super pulley but you can definitely do it on stock internals. intake is probably very important but the header and exhaust probably isnt even necessary. what you will need is a new tune, JR will give you a tune when you buy their kit. best thing to do if youre spending that much on a super is to get FP though.quick question, little off, but has anyone done a super on a stock motor? From what I can find, ppl seem to do a bunch of stuff internally when they add a super, but not much on stock. I know you can go turbo on stock, you just can't get much more than 6psi. lol.
they areI knew it would cost a lot, but I was thinking like 3-5 grand. I don't want to replace everything in the engine just to get 300hp when the Evo/STi crowd is making that bone stock. I wish these Si's were faster![]()
:rotfl:I knew it would cost a lot, but I was thinking like 3-5 grand. I don't want to replace everything in the engine just to get 300hp when the Evo/STi crowd is making that bone stock. I wish these Si's were faster![]()
Power isn't everything, they have their own cons/problems.I knew it would cost a lot, but I was thinking like 3-5 grand. I don't want to replace everything in the engine just to get 300hp when the Evo/STi crowd is making that bone stock. I wish these Si's were faster![]()
Edit: 300 HP supered with stock internals is my goal which is why I know it can be done.
Edit 2: duh! Perfect example. 318 HP, NA. If you look at the parts list (or just measure how long it is) you should understand perfectly.
http://www.8thcivic.com/forums/showthread.php?t=299959
well its for sure possible no doubt, its just not like you buy the ct stage 1 or even 2 and have 300 whp, I had ct stage one and made 224whp and 170tq with no other mods (mustang dyno), I then got stage 2 and a berk HFC, with vitviper currently in the middle of tuning my car, and I would assume about 250whp. correct me if im wrong but even with a decent quality race header and 3" exhaust i wouldnt expect over 280-285 horsepower.
All i was basically stating was that your not going to have a I/H/E civic si through a supercharger kit on it and make 300whp.
I can say however that my supercharged si Keeps up with almost anything i have came in counter with.
I've almost made 300 hp lol just 5 short at 295whp and 210torque. Let me tell you now it's EXPENSIVE! I've spent 15k building my motor and haven't even hit 300! But you pretty much need a k20/k24, ported head, bigger injectors, all valve train, at least a 12:5:1 compression or higher, rods, pistons, rsx type s oil pump, stage 3 skunk 2 cams or drag cartel 4, Walbro fuel pump, good header and exhaust "skunk 2 race header and 76mm exhaust work great) bigger throttle body, bigger intake manifold and a good tuner!I hear ya, and yea i certainly wouldnt expect 300 on a super (at least with standard pulleys) with anything less than a full 3" through the back. Still very doable, as we both agree.
and ESPECIALLY goes to show how hard it is to make 300 HP NA
No, should cost around 10k, multiplying it by 10 times would get him a fire breathing 350 whp+ MONSTER.oh, and to make 300 going NA you need to multiply your budget by 10x![]()
