are you making that assumption because that's what you think would happen when you start to see the valves float?
are you making that assumption because that's what you think would happen when you start to see the valves float?Because the other drop in cams advertise that it doesn't apply to other drop in cams?
You can look at the power curve on the dyno and instantly realize this doesn't apply to them. power would flatline or drop if it was being revved too high.
the power you make with a cam can be somewhat canceled out if you use heavy valvesprings... without the need for heavy valvesprings.
You'll love it if you do. The powerband is crazy looking at an overlay of my K20 with all the bolt-ons and a tune vs. the 24.True, but you also have so much more potential down the road man. K20/K24 is the way to go: torque down low and high revs! I'm so jelly, but in a good way :thumb:
Hoping to do that in a couple years myself....
Probably drops power too, but this is if it doesn't have ptv contact. Perhaps even misfires.are you making that assumption because that's what you think would happen when you start to see the valves float?
just because the power begins to flatline or drop at higher rpm does not mean that the valves are necessarily floating. yes it may misfire.Probably drops power too, but this is if it doesn't have ptv contact. Perhaps even misfires.
It's not an assumption, the internet is a wide vast resource of information.
at what RPM was it recorded ? wait he had oem springs....:facepalm:just because the power begins to flatline or drop at higher rpm does not mean that the valves are necessarily floating. yes it may misfire.
we're getting off topic now. i don't know how well the stock springs and retainers will hold up in the long run with drop in cams but me personally i wouldn't risk it. one misshift or any pull at higher rpms can cause a valve to drop out of no where. remember what happened to this guy:
http://www.8thcivic.com/forums/autocross-sanctioned-drag-racing/276194-new-k20z3-na-record.html
Yes but he wasn't running drop in cams.just because the power begins to flatline or drop at higher rpm does not mean that the valves are necessarily floating. yes it may misfire.
THISTo be fair, a misshift can end a 100% bone stock K20z3. The guys that are mis shifting and making it out OK are getting very lucky.
trueTo be fair, a misshift can end a 100% bone stock K20z3. The guys that are mis shifting and making it out OK are getting very lucky.
they are a mild cam and ips themselves say you can run those cams with their recommended oem spring combo and get away with it as long as you limit the revs but i wouldn't risk it.Yes but he wasn't running drop in cams.
i had titanium retainers on my old ep3. i put over 20k miles on them without any problems. it's not as bad as people think. if you don't want to run titanium, you have other options. iirc, brian crower sells steel retainers and supertech sells aluminum retainers.These DICs seem to be a nice safe cam to run to minimize the tct issues while maintaining OEM valvetrain - which is good. I drive 1500+miles a month and dont feel like having a wear item like titanium in there and having to check wear/fit all the time.
They were svm cams different then the ips but only recommended to 8200 with an oem valve spring retainer option. I know nikos is making these cams but he says they are a different profile than the k2's and plus he had the 2nd revision. They are a mild cam but still more agressive than the dic'strue
x2 failat what RPM was it recorded ? wait he had oem springs....:facepalm:
I run my spoon "dic" cams for 2,5 years with stock spring and retainers, 8800 rpm all day. No problem. As mugen say on a sticker " don't miss shift".just because the power begins to flatline or drop at higher rpm does not mean that the valves are necessarily floating. yes it may misfire.
