Gear grinding
476 Views 5 Replies 6 Participants Last post by  RyanL
My clutch pedal stop working.. so I drove the car without clutching .. now I have grinding B4 it goes into gear.. gears are good but the sound .. sounds like I'm miss shifting or can't find a gear.. plzzz help
1 - 6 of 6 Posts
Can you please clarify as to what you mean by "stopped working"? Is the pedal stuck, or do you need to replace your clutch?
Sounds like it's not releasing and you've just been grinding gears and have now caused damage to your transmissions synchros.
Sounds like you aren't good at speed shifting,,,,,and you need to go back in with a good high quality clutch, not a cheap one,,,, asap
Sounds like it's too late if it's grinding in neutral. Now he needs a clutch and a transmission.
1 - 6 of 6 Posts
