Did you have to grind down your OEM studs to make the wheels fit?They worked fine but the locking nuts are made of really soft metal. I accidentally rounded the edges on a one of them and had to take it to the shop in order to get my spacers removed. You just have to be careful.
How far did the OEM studs stick out after the spacers were installed?
I think my FD2 CTR wheels have ~15mm cavity in them so there is space to handle the studs sticking out without having to grind them down.
Yeah I almost had the same issue with the H&R spacers stripping the locking nuts. Had to use a 12 point thin socket to keep it from stripping.
How low did you drop your car?
Oh I see.I didn't have to grind down the OEM studs, as long as you have some space behind the wheels, I think 15mm should be ok. I don't remember how far the OEM studs stuck out - it's been a while since I had the spacers. my car is lowered about 2.5 inches all around.
not needed if you are able to adjust your camber. The front fender liners get in the way though, so you may have to trim the edges off.Oh I see.
Did you have to roll your fenders to fit the 18 x 8.5 +45 offset wheels you have with this drop?
thanks!Nice clean ride you have
That's clean ride homie. Glad to see someone modding their civic sensibly for a change.
thanks!That's clean ride homie. Glad to see someone modding their civic sensibly for a change.
thanks! pics of the mugen lip are up (check a few posts above yours). Good luck with your buildVery Very clean! Looking forward to pics with your mugen lip. I drive a mugen si w/ a fd1 conversion (cf vis w depo lights). Looking to do the front end soon, still on the fence about getting rid of my usdm mugen lip and bumper for the new preface fd1 style bumper and mugen lip.
thanks!Your build is absolutely beautiful!
Florida. Sorry, I don't have the HFP suspension anymore. total parts probably around 5K.Where are you located? Do you still have the hfp suspension? How much was your total in parts? I want to convert my 08 Si to Type R like you.
thanks!Very nice build!
