221 - 229 of 229 Posts
There's a ground type wire behind my fuse box in the firewall under my clutch mast cylinder fill like in the back upper corner of my engine bay...any idea what that could be for? Had a fuse type connector at the end of it like how a fuse has the two metal pieces at the bottom except this is one metal piece...my car is an 06 civic si supercharged, aftercooled, meth injected...deff not for the meth inj and pretty sure not for the aftercooler
My car is 2008 Honda Civic coupe. I'm installing remote starter. I've connected all wires but can not find Factory Alarm Disarm.
"Factory Alarm Disarm - brown (-) dr kick or MICU, 34 pin plug, pin 31"
I see 3 big plugs. The first (top) one is 41 Pin, the second one is 32 pin. There is no 34 pin plug. Also which side is Pin 32? What is dr kick?
Thanks
Anyone know where I can tap into the under hood fuse box to get 12v only when the car is on? I'm trying to wire up some lights as DRL and would like to avoid passing wires through the firewall to use the internal accessory fuse.
I have a 2010 Si coupe with after market spec- D headlights driver side was working but not passanger side wasn't fuze was blown no big deal replaced it in the pasted and works now tho after replacing the fuze neither right or left low beam will turn on HELP!!!!
FYI - For the interior fuse box
#5, 6, and 20 are always Hot
#8 and #22 are switched Hot
YMMV as these were empty slots in my 2011 LX (no audio amp, no fog lights, etc.) I used #22 to power my hardwired A119 dashcam.
2010 Honda Civic LX Fuse Question
I have a 2010 Honda Civic LX, and my accessory socket isn't working. I bought the car in that condition, but what I'm wondering is, is if it's the problem with the accessory itself or I just need to change the #28 and #29 Fuses?
