Here's a list of fuses and location #'s.. hope this helps!
Updated: Also included wires & locations!
Under-Hood Fuse Box
1. 100A - Main Fuse
70A - EPS
2. 80A - Option
50A - Ignition Switch Main
3. 30A - ABS motor
30A - ABS F/S
4. 50A - Headlight Main
40A - Power Window Main
5. -- Not Used
6. 20A - Fan Motor
7. 30A - Main Fan Motor - A/T
20A - Main Fan Motor - M/T
8. 40A - Rear Defroster
9. 40A - Blower
10. 10A - Hazard
11. 15A - FI
12. 15A - Stop, Horn
13. -- Not Used
14. -- Not Used
15. 7.5A - Oil Level Sensor
16. -- Not Used
17. -- Not Used
18. 15A - Ignition Coil
19. 15A - FI Main
20. 7.5A - MG Clutch
21. 15A - DBW
22. 7.5A - Interior Light
23. 10A - Back Up
Interior Fuse Box
1. 7.5A - Power Window
2. 15A - Fuel Pump
3. 10A - IGI ACG
4. 7.5A - ABS
5. 15A - Audio Amp
6. 20A - Front Fog Lights
7. -- Not Used
8. -- Not Used
9. 7.5A - ODS
10. 7.5A - Meter
11. 10A - SRS
12. 10A - Right Headlights High Beam
13. 10A - Left Headlight High Beam
14. 7.5A - Small Lights (Int)
15. 7.5A - Small Lights (Ext)
16. 10A - Right Headlight Low Beam
17. 10A - Left Headlight Low Beam
18. 20A - Headlight High Beam Main
19. 15A - Small Lights Main
20. -- Not Used
21. 20A - Headlight Low Beam Main
22. -- Not Used
23. -- Not Used
24. 20A - Moonroof
25. 20A - Door Lock
26. 20A - Dr Power Window
27. 20A - HAC Option
28. 15A - Rear Accessory
29. 15A - Accessory
30. 20A - Fr Pass Power Window
31. -- Not Used
32. -- Not Used
33. -- Not Used
34. -- Not Used
35. 7.5A - Accessory, Radio
36. 10A - IG2 HAC
37. 7.5A - Daytime Running Lights
38. 30A - Front Wiper
Ignition Wires
White - Constant 12V
Blue - Ignition
Yellow - Starter
Accessory - Orange
Second Accessory - Red
Other Wires
Vehicle Speed Sensor (VSS) - Blue wire (next to purple) on Radio Harness
Power Lock - green (-) dr kick or MICU, 34 pin plug, pin 28
Power Unlock - gray (-) dr kick or MICU, 34 pin plug, pin 27
Parking Lights - red (+) dr kick or fuse box, top 42 pin plug
Parking Lights - gray or red (-) switch or MICU, 20 pin plug, pin 13
Door Trigger - see notes (-) ea kick or fuse box, top 42 pin plug
Notes: The LF door is green in pin 37. The RF door is lt. green in pin 3. The LR door is brown in pin 17. The RR door is gray in pin 2. Use all four wires and diode isolate each.
Hood Pin - lt. blue (-) pin sw or fuse box, mid 21 pin plug
Trunk/Hatch Pin - blue (-) dr kick or fuse box, top 42 pin plug
Trunk/Hatch Release - green (+) dr kick or fuse box, top 42 pin plug
Factory Alarm Arm - orange (-) dr kick or MICU, 34 pin plug, pin 32
Factory Alarm Disarm - brown (-) dr kick or MICU, 34 pin plug, pin 31
Brake Wire - lt. green (+) switch or fuse box, top 42 pin plug
Parking Brake - orange (4dr) or lt. blue (2dr) (-) parking brake switch
Horn Trigger - orange (-) switch or fuse box, rear 16 pin plug
DEI 689M
Main Harness
Green: (-) door trigger, tap this into the door trigger input on the brain of the alarm. (DIODE ISOLATE!)
Purple: not used.
Black/White: Connect to black/white on the brain of the alarm.
Dark Blue: (-) status input, hook up to a blue or blue/white status output on the brain of the alarm
Light Blue: (-) status output, probably not needed
Yellow: 12v+ Ignition
Red: 12v+ Constant
Black: Ground
2-pin harness
purple: to black ground wire @ clutch pedal (yellow switch)
black: to orange trigger wire @ clutch (yellow switch)
Under-Hood Fuse Box
1. 100A - Main Fuse
70A - EPS
2. 80A - Option
3. 30A - ABS motor
30A - ABS F/S
5. -- Not Used
6. 20A - Fan Motor
9. 40A - Blower
10. 10A - Hazard
11. 15A - FI
13. -- Not Used
14. -- Not Used
16. -- Not Used
17. -- Not Used
19. 15A - FI Main
21. 15A - DBW
23. 10A - Back Up
Interior Fuse Box
2. 15A - Fuel Pump
3. 10A - IGI ACG
4. 7.5A - ABS
5. 15A - Audio Amp
7. -- Not Used
8. -- Not Used
9. 7.5A - ODS
10. 7.5A - Meter
11. 10A - SRS
20. -- Not Used
22. -- Not Used
23. -- Not Used
24. 20A - Moonroof
25. 20A - Door Lock
29. 15A - Accessory
31. -- Not Used
32. -- Not Used
33. -- Not Used
34. -- Not Used
36. 10A - IG2 HAC
Ignition Wires
Blue - Ignition
Yellow - Starter
Accessory - Orange
Other Wires
DEI 689M
Main Harness
Purple: not used.
Red: 12v+ Constant
Black: Ground
2-pin harness
