1 - 8 of 8 Posts
Hi everyone, I've a 2006 Civic EX and I'm reading a -0.5 amp draw; I pulled the fuses one by one and found it's Fuse 23 that's the problem. Unhooked the nav/radio unit thats on #23 to see if that would help, parasitic draw went down to -0.3 but this still kills the battery in 48 hrs or less... nowhere near the -0.05 limit for OK battery draw when car is off.
Fuse 23 controls the: Audio Unit [now unhooked], Data Link Connector (DLC), Gauge Control Module (Tach), Gauge Control Module (Speedo), Hazard Warning Switch, Immobilizer-Keyless Control Unit, Multiplex Integrated Control Unit (MICU), Motor Control Module (MCM) (Hybrid), BCM Module (Hybrid), HandsFreeLink Control Unit.
I don't even know where to begin to find which component is the remaining parasitic draw culprit. I don't even know where most of these things are located in the Civic. Any diagram websites I can use or general advice? I'll need all the help I can get!
My main questions, though, are:
1. Can I just live without Fuse 23 in? The car starts and I drove it just 10 feet and it seemed fine.... is there anything life-threatening by leaving all those systems out?
2. In what order should I start trying to unplug the components or what are the biggest culprits here? Any ways I can find out besides manually pulling each one?
Thank you so much for even little help– this is driving me mad!
Im sure its the immobilizer/security system, the fuse. Did you check how much the alternator is putting out? Is the battery old af? Other than that I had the interior light switch inside the door frame stick one time and I had to pump it a few times to get it unstuck, it was good after that.
I had a similar issue, '08 EX Cpe, and tried for weeks to figure it out, because if I drove the car daily it did not happen, but if the car sat 3 or 4 days the battery would be drianed. After replacing the battery, (AAA), checked the charging system using their simple hand held system they reluctantly replaced the battery.. good for a week or so, called again they checked the battery, charging, and starter system again and said it ain't the battery or the charging system.
Trouble shoot, measure with a volt/ohm-meter, (not the best tool for the issue, for correct amp reading you really need a clamp on inductive probe), remove fuses one by one, then all to no avail.
It became frustrating because I trave and leave the car at the airport or in the driveway for days at a time, come home to a dead battery.
Ended up taking it to the dealer, and it took them 3 weeksto diagnose and resolve the issue. They claimed it was the fuse panel under the dash, then called me 3 days later and said that wan only part of the issue, days later called and said it was really fixed now and the gage cluser was also bad.. being an engineer I said BS no way were they both bad, one or the other or both but not a fuse panel partialy bad plus a bad cluster.. but argue as much as I could stand with cs dude and managers they refused to budge, although I did manage to get the price down from $2000 to$1600. and this is a dealer that I have purchased 5 Hondas (3 civics and 2 accords) from.
There is a post around with all the wire diagrams posted here somewhere.
So all I can say is good luck...
Discussion Starter · #4 ·
I can get the battery from dead to full charge with half an hour of driving so alternator is good as far as I know, battery is brand new shop bought and installed.
How would I get at the immobilizer/security system? I'm not skilled enough to deal with soldering a computer component, and I doubt it's got it's own unit to just unplug(?)
At this point I'm just thinking of installing a kill switch so the battery dose not drain when I leave the car. Just... such a pain in the ****.
That's kind of funny, I fought my issue for a coupe months and at one point had the same idea.
Everything should shut down a couple minutes after you leave the car. So could it be that there is a sensor that doesn't realize the door is closed or something?
Discussion Starter · #8 ·
Well yes. Fuse 23 runs a bunch of clusters including the keyless entry sensors and power door lock controls and some car alarm sensors. So if "a sensor" is off there isn't a way I know of to isolate which one (since there are tons on this circuit) without pulling each one, one by one, till I find the bad one. That means taking apart the whole car almost. Not possible for me. I've read the error codes from the internal error report system but... nothing.
1 - 8 of 8 Posts
