Full-Race 06+ Traction balls!!!
12959 Views 319 Replies 69 Participants Last post by  Midknight
Need more traction? We got the solution.
2006+ Honda Civics that need increased traction, reduced wheelhop and better handling - the large rubber LCA bushing is your enemy. During acceleration, braking or turning, the Honda Lower control arm has a large rubber bushing that distorts under load. This distortion allows the lower arm to move back and forth as the forces from the tire and car compress and squish the bushing into different shapes.
**Highly worn bushings will develop a "thump/pop" sound coming from the suspension pivots during low speed bumps.
The soft bushing was designed to give a smooth cushioned ride, but the downside of this smooth ride is low precision and low accuracy of the suspension components. This movement known as "Deflection" of the Lower Control Arm (LCA) allows the wheel to shift forwards, backwards, up and down, completely out of the geometrically intended location. This is due to the fact that the stock Honda suspension was not designed to handle the forces introduced from a high power/high speed vehicle with wide wheels and sticky tires. Because of this deflection, the alignment settings of the car become useless, and the wheel actually moves forwards into the fender well (on high power cars, the tire can actually hit the bumper cover). As the suspension geometry and alignment move around, the car toes out and caster changes erratically. The available traction of the vehicle decreases as overall traction is reduced and wheelhop can result - repeatedly doing this on a high power car can mean damaging axles and gears in your transmission.
The concept of the Traction Ball is very simple. If the suspension does not have any inaccurate or sloppy movement (due to bushing flex) the suspension geometry will be correct. By eliminating the big rubber compliance bushing in the 2006+ Honda Civic front suspension, we are able to eliminate slop in the LCA and significantly improve handling. Traction balls stop deflection because bushings cannot flex/move/change with the solid-mounted heim joints.
With traction balls installed, the LCA does not flex at all - it is completely rigid. The steering and suspension is immediately and drastically improved; you can new feel every input and change in the road surface. Steering is now very sensitive and a lot lighter. The durability of these units is superior to the stock units and they are perfectly suited to both street and track use. This design is not uncomfortably harsh during driving and really an improvement in all regards. This product requires no maintenance, however it is a good idea to inspect them everytime you change your oil. Tap the LCA with a rubber mallet and listen for any noises. Bearings can easily be replaced if needed, however we have not had to replace one yet.
For installation info please take a look a this thread.
http://www.8thcivic.com/forums/suspension/242952-diy-full-race-traction-ball-install-7.html
Full-Race would like to thank everyone who participated in the introductory sale on the traction balls. We have officially ended our introductory pricing and is now set at the suggested retail price of 299 shipped anywhere in the continental U.S. Thanks to all the 8thgen members for all of your support, build threads and reviews! Like always, please feel free to PM me or email me at [email protected] if you have any tech questions, concerns, and inquiries.
If you like to place an order you can email me at [email protected], send payment via pay pal to [email protected] and entering screen name in notes field, or by giving us a call @ 602-437-2101 ext:20
Thanks for looking!
[email protected]
21 - 40 of 320 Posts
lucky ? you can custom make these for less.... just saying.
dope product :thumb:
I'd like to see someone make something come even close to the quality of these for less. Geoff went through so many revisions to make these perfect for you guys. I can tell you first hand as I already have a set and making a detailed review video, that you can feel the difference with these.
My old bushings were shot, old, worn out from excessive boosting. Now when I drive normal cruising at 75mph, my car wobbles or vibrates really bad. It's all gone and the car feels planted to the ground. Brett has the same thing and he can tell you about the quality as well.
Ok guys let's keep the arguing out of this thread and the price is what it is and its a good price.
Just ordered my set. Gonna be the best $210 I've spent at least in the suspension department. My car is so unpredictable at WOT in 4th and 5th gear from the LCA deflection that it will literally change entire lanes with the steering wheel locked straight with both my hands on the wheel. With these traction balls that will be completely eliminated.
I will also do a DIY install using the Snap-On Honda Compliance bushing tool. This will show you guys that this can be done in the driveway without the need for a press.
:word:
It looks like the Honda ball joint puller setup I rented from Autozone will work for this as well.
mike knows how predictable my car is with these in and how straight the car tracks, they really do make a world of difference
Can't wait Mike. I'm waiting to hear more reviews before I pull the trigger and place my order.
Don't even wait man. These are a MUST HAVE for high HP turbo Civics. The difference in the way the car feels, responds and tracks overall is like night and day. Just pull the trigger now. Trust me.
Just placed my order! :dancing:
waiting on review for a couple months to see whats the result of these anyway good work full race
just placed my order too. im tired of random lane changes at wot. i hope this also helps wheelhop at launch.
Did you design any for the rear? My rears are popping like crazy.
Cant wait for your DIY :)
Will naturally aspirated guys benefit from this? Im more of a suspension junkie than anything i like the feeling of a nice tight well balanced car. Im sure now over the 5yrs i have had my car with ny roads and being lowered my bushings in the lca's took a beating and can use a freesh set so why not just use these.
I'm pondering installing these on my brand new stock car. Yes, they'll enhance the handling of the car period.
post reviews on these after testing for a couple months maybe say 2 months hard drive launching u know even regular driving
these have been in my car for a couple months everything is still holding up perfect
:facepalm: there's no need for these in the rear as there's no suspension geometry shift due to drive tires pushing/pulling.If you have a noisy suspension then I suggest buying a better suspension or have a mechanic look at it.
lol at the rear traction balls.
Buy a sway bar, reinforce the linkage to the sway. Rear= done.
What does FR have to say about the rear end of this car? I think with those ^ mods, the rear is perfect.
