1 - 19 of 19 Posts
Well its has come time to make my car a heavy commuter for my wife so I needed to take off my Tein Flex Coilovers with EDFC and install the factory suspension. My loss your gain. I have a little more than 10k miles on these coilovers. From what I've found this system is going upwards of $2400 new right now. I'm asking $1800 or a reasonable offer. Here's some info about the coilovers from Tein
From TEIN's Website:
Description:
TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The FLEX damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. We have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability.
Additional Features:
• Steel Construction
• Twin Tube internal construction
• Ride Height adjustable via threaded body and spring seats
• 16 way adjustable dampers, compression and rebound combined
• Pillow ball upper mounts for increased steering feel
• Upper camber adjustment on front for strut type vehicles
• Larger piston diameter for strut type front and rear (22mm)
• EDFC (Electronic Damping Force Controller) compatible
• Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
I have Tein Flex's on my Si and the handling is amazing! Of course thats due to a good suspension set up (neg camber, rear sway bar) that I did shortly after installation. The new owner will be happy with the coilovers, unless traveling down a bumpy road. ha ha
Discussion Starter · #14 ·
I had a negative camber set up, with the rear sway, a cusco underbrace and a carbing tower bar. It definetly handles...that's for sure
1 - 19 of 19 Posts
