1 - 6 of 6 Posts
Precision Power PCX-480 - $200 Shipped
Specs:
Car Amplifier (PCX 480)
Features: Channel: 4 4 ohm: 80 2 ohm:
160 Bridged: 320
Damping: >500
S/N Ratio: >110dB
Dimension: 2.375' x 10'
Length: 18.5'
THD: 02%
Power Input: 4 Guage
Freq. Resp.: 4.5-100k
I/P Sens.: .15-12V
X/O Slope: 12dB
X/O Freq.: 30Hz-4KHz
X/O Type: 2 way
Input Type: 12 vDC
Cooling Fan: Yes
QBass: QBass
A/D/S Old School 625x - $160 Shipped
Specs:
6 channel: 6 x 25 5
channel: 1 x 50 + 4 x 25 4 channel: 2 x 50 + 2 x 25 3 channel: 3 x 50 DC Power: 30a
Input Sensitivity: 100 mV
SNR: 100db
If you know A/D/S, you'll know it will make above rated power specs. Great amp that can run midranges and tweeters with little effort.
Discussion Starter · #2 ·
SoundStream USA 204 - $30
Specs
4 x 40W @ 4 ohms
4 x 60W @ 2 ohms
2 x 100W @ 4 ohms bridged
THDL <0.1%
Freq. Response: 20Hz ∼ 20kHz (±0.5dB)
Stereo Separation: >90dB
Damping Factor: >200
Fuse: Internal 25A
Dimensions: 10.1" x 8.2" x 2.2" (25.7cm x 20.8cm x 5.6cm)
It powers up, not sure about the functionality.
Soundstream USA-204
Precision Power Sedona 460IX $115-Shipped
Specs:
4x60w rms at 4 ohm
4x100w rms at 2 ohm
2x200w rms at 2 ohm
Here's some other random things I have for sale
7" Screen with all mounting brackets $65 Shipped
One Set of StreetWires ZN 6 RCA's - $20
Sony MEX-5DI- $50
Radio and display works fine, but motorized faceplate gets stuck folding down. Motors works, just needs some minor repair work.
Two Fuse Holders (1) 0/1 gauge, (1) 4/8 gauge - $20ea
Shift Knobs and Momo Brake Handle - $20ea
Discussion Starter · #4 ·
Orion DEQ30 with Fiberglass Rack - $250
This will be the finest example you will see of these processors, 9/10 for only scratches are on the screw holes. It is FLAWLESS! Comes in original box with original manual and paperwork.
BNIB Peerless (Vifa) XT25TG30-04 - $65 Shipped
Specs:
Vifa 25mm Dual concentric diaphragm
Non-reflective dual chamber
Controlled directivity
Wave-guide center plug
copper-clad aluwire VC and braided leads
Flange 104mm
Cutout 73.5mm, D 41mm
Znom 4 ohm
Re 3.0 ohm
[email protected] - mH
fs 500 Hz
Qms 2.50
Qes 0.71
Qts 0.55
Mms .30 g
Cms - mm/N
Sd 5.4 cm2
BL 2.5 Tm
Vas 0.02 ltrs
Xmax 0.5 mm peak
VC Ø 25 mm
Sensitivity
2.83V / 1m 91.5 dB
Nom. Power DIN 140 W
Magnet weight 240 g
Original SI Stock Stereo Speakers (minus tweeters if you need replacements) - $50
Lastly I have a 10" Fiberglass Box with Eclipse Sub for Sale It's fits the coupe. $200
Will take pictures on request
1 - 6 of 6 Posts
