1 - 9 of 9 Posts
Hello my fellow 8th Gen Peeps,
Here we have a bunch of parts off a 2011 Civic Si with 122k on the clock. The only parts I have are the ones listed. Located in Illinois, 60181 and will ship at buyers expense.
1. Charge harness (damaged plug to engine harness/repairable)-- $50 obo
2. Engine harness (damaged plug to charge harness/repairable) -- $80 obo
3. Cam sensors -- $40 for both
4. Crank sensor -- $20
5. Flywheel -- $old!
6. Half shaft -- $old!
7. Dip stick -- $30
8. Cylinder head $old!
9. Valve cover -- $50
10. Fuel rail + fuel injectors -- $80
11. Water pump -- $50
12. Oil Cooler -- $50
13. Coil packs -- $50
14. Vtc solenoid $old!
15. Alternator -- $50
16. Transmission -- $old!
17. Map sensor -- $15
18. Used floor mats f/r -- $old!
19. Rear wheel bearing (brand new from MOOG) -- $65
20. Passenger side fog light (depo) -- $30
21. stock Intake tube + temp sensor-- $25
22. FA5 driver's side fog light + plastic housing $80
23. After market fog light wiring + dash buttons -- $20
24. Crankshaft -- $100
25. Oil squirters -- $15 each
26. Pistons w/ hardware -- $30 each
27. Flywheel bolts (8 total) -- $25
28. Pressure Plate bolts (6 total) -- $20
29. Em1 cmc -- $25
30. 04-05 Tsx Throttle bodies -- $50 each
31. Pressure plate/clutch disc-- $40
Well so far, I have a injen sri on n a skunk2 cat back, next week I'm putting the skunk2 stage 2 cam and nst lightweight under drive pulleys on, need the injectors cuz the cam, then a week or 2 after that I'm taking it up to Evan's tuning ( like 40mins from my house ) n getting it dyno-tuned ( just so its driveable ). After that, getting a weapon r intake manifold, retuned so its driveable, then mid next year hopefully boosting her.
So how much for the injectors ???
Discussion Starter #6
That's a good plan. Hmm. Is that 155 hp average for the mods you're putting in? It would seem like the R18 could squeeze out just a little more..
I have the injectors up for $80 + shipping or best offer.
Discussion Starter #8
Would you do $60, how much is shipping. I'm very serious about purchasing lol
I'm guessing that shipping is around $12-13, depending on your location. Tack on Paypal fees and we are getting closer to $20 more. I couldn't do $60 right now. Sorry.
1 - 9 of 9 Posts
