Since I just got a new retrofit, I'm going to sell my previous retrofitted headlight. It is an 09 OEM Sedan headlight retrofitted with G3 bi-xenon projector kit. It included a pair of headlight with G3 projector retrofitted, white CCFL angel eyes around the projectors, a pair of 4300K bulbs, and a pair of wiring harness. The cutoff been modded to step cutoff. There is a DIY I posted for this retrofit, and if anyone interested to know more details, you can see it at http://www.8thcivic.com/forums/ligh...bi-xenon-retrofit-under-250-easy-diy-pnp.html
The headlight been installed on my civic since Sept 09 and still works very well.
Here are some pictures:
There is a broken tab on the passenger side, but it is fixed and worked without any issue.
There is a pair of PnP harness included, and it covered the bi-xenon hi/lo operations, and custom circuit to power the angel eyes with DRL. But since it is the first PnP harness I made, it is a little bit bulky and I'm a bit embarrassing to sell it. So, if there is a buyer of this headlight, I will re-made the harness, which is a lot cleaner then what you see in this picture.
And here is the cutoff pictures I took before. Sorry I can't take more output pictures as it is no longer installed on my car.
The price for this is Sold.
Update about the PnP Harness
As I said, I will prepare a new harness for the buyer, so the buyer will have some choices on how the light works.
For the 9005 High Beam Bulb:
1. Work like stock - 60% intensity at DRL, fully on when High beam.
2. Only used for DRL.
3. Only used for High Beam.
For the CCFL Angel Eyes:
1. On with DRL.
2. On with DRL and Low Beam. Basically it means it will on almost all of the time, since you will be have either DRL or Low Beam on at any time except when you just started your car.
The basic (and recommended) configuration will be #1 for 9005 bulb and #1 for angel eyes, but buyer can choose any combinations above with $20 additional.
1. On with DRL.
