1 - 9 of 9 Posts
Up for sale is a used AEM TruBoost Boost Controller/Boost Gauge. I bought the Greddy Turbo and the seller shipped this with it, but I had already bought a Blitz Boost Controller ahead of time. According to the seller, he used this unit for about 3 months, and I never used it or even installed it, just been sitting in my room. It comes with the black faceplate and buyer will need to buy some rubber hose in order to run it from the solenoid to the wastegate.
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
No external interface required for programming!
Quick connect technology eases the installation process
Two user selectable boost settings with peak boost memory
Scramble boost setting allows user to momentarily change boost levels
User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
User configurable gauge includes 24 scalable LEDs
One (1) low-side output included for warning lights
INSTALL INSTRUCTIONS...
http://www.aempower.com/images/products/Installation Instructions 30-4350.pdf
I'm asking $175 SHIPPED TO THE LOWER 48
1 - 9 of 9 Posts
