1 - 2 of 2 Posts
When cutting out the plastic piece to make the hole for the fog light itself, I notice there is a small notch that is already cut on the right of each side. Do you cut the piece on the inner side of the notch or the outer. I hope this makes since, basically should the hole be smaller or the same compared to the notch? Thanks!
Scrodums
The hole will be *slightly* wider. Notice that emphasis around slightly. You would really need to take your time to get the fogs to sit completely flush in the plastic. Mine is not anywhere near perfect, but you can't see the gaps because there is not light coming in from the inside. You'd have to look really closely to notice it.
1 - 2 of 2 Posts
