1 - 20 of 25 Posts
Anyone else with K2 fogs on their car?
Yeah, I'm using the K2 harness. You have to make sure everything is plugged in from the harness. If that doesn't work then check all of your grounds.
^^Did you only plug in the red/white wire under the brown and black wire in the middle harness?
Yeah, it doesn't come with the 2 other wires that are supposed to plug into the harness.
1 wire gives you the dash indicator (not necessary)
1 wire i think controls when you can have the fogs on (this prevents you from having the fogs on with your parking lights or high beams)
1 - 20 of 25 Posts
