1 - 3 of 3 Posts
· Registered
Would it be possible without insane amounts of work or even worth it to throw a fk8 turbo on my 8th gen si. I’ve got a good deal on one and just don’t know if I can even make use of it.
· Registered
08 Honda civic fully built turbo R18
No Housing are different. Just buy the proper turbo a Garrett. I have a gt25 with .64 housing using t25 housing if you’re interested. New center cart ledge less then 5k miles
· Registered
I guess it depends on the engine you have in the 8th gen Si. If it is a K20Z3, it has 11:1 compression ratio. Be careful how much you boost it! No matter what, you will need a new tune. That means getting a Hondata Flashpro or other, and also getting it on a dyno with a tuner guy that knows what he is doing. Check out those additional costs. Don't blow up your motor.
1 - 3 of 3 Posts
