Alright i've read the DIY here and countless threads. I'm going to do my first oil change on my own and just want to make sure I have everything set before leaving my only form of transportation on jack stands and without oil.
1. I already have an amsoil EA013 oil filter on the car. Is this a different size than stock and what oil filter wrench or tool should I use to loosen it.
2. Is there a gasket that I must replace when changing the oil filter. Or must I make sure that the old oil filter doesnt leave a gasket behind causes a leak when the new oil filter is added
3. Is a copper crush washer from advance auto parts or pepboys the same as the crush washers from the dealership? Are there different sizes and I have to find the honda size? If so what size does honda use. I really would like to avoid the dealership at all costs.
Thank you very much
Thank you very much
