Wow. This was not exactly the best overall experience. I had a friend help me on Monday night. For the most part everything went fine as far as getting everything off. The only exception being, trying to get the belt off (the tensioner is rather hard to figure out). Anyways the big problem came after getting everything off and getting the alternator and water pump pulleys on fine. I got in my car and put it in 5th gear and held the brake while my friend put the crank pulley on. The problem was that he started the bolt with an impact wrench and cross threaded it inside the crank. I was scared out of my freakin mind. We left it sit for a couple days til I figured out what to do. Finally I talked to my neighbor who works for a machine shop and is like a genious with metal working. Thankfully he was able to get a tap and we fixed the hole and torqued the bolt to the spec yesterday. My advice to everyone is not to use impact wrenches at all except to try to get that bolt off!!! You can do a lot of damage with an impact wrench, so BE CAREFUL!!! If too much damage was done I would have had to buy a new crank and get it installed which would have cost close to $1500 prolly.
P.S. As far as performance from these pulleys. The car has better acceleration, its not a drastic improvement but is definitely more fun to drive and worth it.
