Should I fill my keyhole on the driver door?
  • Fill it
    Votes: 14 35.9%
  • Leave it alone
    Votes: 25 64.1%
1 - 20 of 67 Posts
Since my car is in teh shop getting body work done I was thinking of filling in my keyhole on teh drivers door......I've never used it in the almost 2 years I've had teh car. I never use a valet so teh only time someone gets my key is if I take it to teh shop. I only have 2 days to decide before they paint my door
what do you think?
Shave the door handles and put door poppers in while your at it... :rotfl:
i would leave it. i had to use mine for the first time the other day. my damn battery died. i tried it once when i got it and then last week. twice in 2 years but you will be pissed if you need it cause your battery dies. just my .02
that is my key/clicker battery not the car battery.
:yeahthat: you beat me to it man
Discussion Starter #7
I never thought about the battery dying.....I do own a slim jim tho
Paul,
The shaved would be a sick idea only cons are the quality of the kits that are out there and also the placement of where you going to put it because sometimes if you put it in the wrong spot it will have issues opening and closing.
great minds think alike
i do what i can to help. *brushs off collar*. jk. when you need the key hole you wont have it. no one notices it anyways. its not like you walk up to the car and go.... damn thats an ugly key hole. most people are looking at the car instead.
Discussion Starter #16
Here man, might want to try this instead...I remembered reading this a while ago and wanted to try it, but forgot about it...now I might have to go do this as well. You'd be interested in the part towards the end of this DIY (steps 11+).
(Pic Heavy)
http://www.8thcivic.com/forums/showthread.php?t=4302&highlight=door+pull
I saw this when it was posted but theres one problem...this is for a sedan.....I have a coupe. Door handles are different....thanks for looking :thumb:
He ordered the rear handle and used it for the front
damnit. i was actually considering this. never mind.
Well I have a coupe too...maybe that's why I never got around to doing it either. Shouldn't it be pretty much the same procedure thought, just buy a keyhole cover for the coupe instead? Maybe have to dremel a little bit different of an area or something, but should be similar I think.
1 - 20 of 67 Posts
