1 - 4 of 4 Posts
SO been wonderin, IYO would the car act funny, idle bad studder hesitate or any other misfunction worth mentioning if I were to put BC stage 2 FI cams in my motor (with the spring and retainer set of course) instead of the stage 2 NA cams while waiting for Redshift..??? I am running N2O though... :xyxnervou
yea...you have no way to tune it to run correctly. besides the point of that the cams are obviously made for a FI setup which would make it that much worse. even after getting redshift, do you know that you will be able to tune the supercharger to work with teh cams...if i was you i would wait until you have the FI setup to get FI cams.
You don't tune the s/c, you tune the ecm. unless you have the adjustable parts to tune further. i.e: fuel pressure regulator, cam gears, etc.
1 - 4 of 4 Posts
