1 - 8 of 8 Posts
08 Civic LX Sedan - Right turn signal is blinking fast, bulbs are good. Left blinks normal and I even swapped left and right bulbs thinking if bulb was being flakey it would follow to the left. Any one ever run into this?
Same thing happen to me, right side was blinking fast. But once replaced with new bulb it works normal. Did you replace both bulbs on right side front and back?
There is only one front and one back, isn't there? I swapped the one from the right to the left and it still blinked fast.
The bulb blinks and appears to have a good connection. There is no corrosion in the socket either. I assume you mean to rotate the bulb in the socket?
Did anyone get an answer to this? My right turn signal blinks super fast, but whenever I get home to check the bulbs it blinks at the same speed, and all of them look bright. I could see the reflection of my signal as I was driving and it looked like it was normal while inside on the dash it was fast.
1 - 8 of 8 Posts
