141 - 160 of 395 Posts
· Registered
Hello all,
I'm from Canada, with an 09 Si Coupe, and I was wondering if there was a way to enable the TPMS on it? Is it just a matter of buying and attaching the sensors? or do I not have the firmware or the component on the car for it.
TIA!
· Registered
hey, my tpms light never came on when my tire pressure was low. it looked fine, but when i check the pressure it was at 8psi. i been drivien like that for a few days before some one told me my tire looked flat. the whole time my tpms light never came on. why? i have a 07si coupe.
· Registered
::face palm::
TPMS was implemented on 2008 Civics.
I'm sure that has been mentioned numerous times in this thread already.
· Registered
Discussion Starter · #146 ·
what exactly is VSA and what are the pros and cons of it on/off
VSA = Vehicle Stability Assistance.
Youd be better off searching than having me try to explain here as how VSA functions doesnt really have anything to do with this thread
· Registered
suhkim1 did you happen to try that tool out yet. I think you will be a god among men if that tool works and you can verify it lol
even better if you create a DIY for those of us that like pictures :)
149 is a little steep but i guess not compared to what the dealer would charge you.
· Registered
Discussion Starter · #152 ·
why can't the dealship just totally disable the whole system by removing the sensors and the tpms control box (or wat ever it is). and just put in regular valve stems
... because it is federally mandated that all 08+ vehicles be equipped with tpms
· Registered
hey I just received ateq quick set tool today.
here is good news OUR CARS ON THE LIST!!!!
I have 1 more autox is left on this year, after that I going to put on my
winter set. i will post more updates.
· Registered
Low Tire Pressure - This light is supposed ot look like a tire with a '!' over it but looks more like a horseshoe.
This indicator means one of your tires (or all) are below the allowable threshold. This light can be a faulty
sensor, but is most likely a low tire, be it from a slow leak, time, or temperature change. Fill your tires up to
the recommended 32psi (or more), and drive for 5 minutes, the light should shut itself off. If it does not,
take car to dealer, it's a faulty sensor.
So, do i just pump up my tires? how do i know if it's 32psi or not?
· Registered
Discussion Starter · #156 ·
You should use a tire pressure gauge. Most air pumps have one built in, but getting your own at autozone for $5-10 is certainly worth the investment.
· Registered
Discussion Starter · #159 ·
How long will it be before someone comes up with a pressurized box that you leave in the trunk and throw the sensors in it and never have to deal with them again?
never, because it will not work... this has been discussed
