FAQ - Tire Pressure Monitoring System (TPMS)
414905 Views 394 Replies 170 Participants Last post by  ichheibeangel
Since there has been, what seems to be, an influx of questions regarding this system I figured it would be good to make a sticky with as much useful info as possible. I am by no means an expert... but Ive been dealing with the system enough to heave learned a few things here or there.
I'll be updating this over the course of the next few days since I can only write a bit at a time in between work and/or other things. If you feel there is something I missed that should be added, type it up and I'll put it in the 1st post. Also, if you feel some of the info I have is misleading or erroneous... let me know and we'll see about correcting it.
_________________________________________
First things first, there are 2 different indicator lights associated with the TPMS system. It is useful to know which light is which and know what causes each one so that if/when you see them, you know what to check for.
Indicator Lights:
Low Tire Pressure - This light is supposed ot look like a tire with a '!' over it but looks more like a horseshoe.
This indicator means one of your tires (or all) are below the allowable threshold. This light can be a faulty
sensor, but is most likely a low tire, be it from a slow leak, time, or temperature change. Fill your tires up to
the recommended 32psi (or more), and drive for 5 minutes, the light should shut itself off. If it does not,
take car to dealer, it's a faulty sensor.
Tire Pressure Monitoring System - This indicator is actually the yellow letters TPMS located in the upper-right
portion of your dash. This indicator means there is a fault in the system itself, be it a faulty sensor, a dead
module, sensors cannot be found or what have you. Take it to the dealer, they will pull an error code (or not if the module is dead),
and replace the affected item.
Onto the FAQ:
1. My Low Tire Pressure light came on but all of my tires look and feel fine. What is wrong?
Please do not be fooled by what you can 'see' and 'feel' by looking at your tires. Every tire is different...
but when it comes to stock wheels/tires, it is likely at 32-33psi. The threshold for setting off the
Low Tire Pressure light begins at 27-28psi.
The different in look/feel between 33 and 27psi would barely be noticeable to the human eye.
So please, before you assume its fine, buy yourself a tire pressure gauge at your local auto store.
They are cheap and very useful.
2. My Low Tire Pressure Light was on, I found the tire that needed air and fix it, but the light is still on when I turn the car back on.
Once the light is on, it stays on until the car can gather enough information to determine that the issue has been fixed. The TPMS system
cannot gather info while the car is not in motion.
If you are 100% sure you remedied the issue, drive your car around for a minute or two making sure you get it up to at least 20mph. After
a minute or so, the sensors should be activated and should have gathered enough info to know that there is the proper pressure inside the tire.
3. My tires dont have any leaks, why did my Low Pressure Light go on?
Most likely, the cause of this is the change in air temperatures as the seasons
change. As it gets colder, the air inside your tires will get more dense, causing
less pressure and possible setting off the indicator.
4. If I get new wheels, will my TPMS still work?
No, with new wheels, the system will not work because the sensors are not attached
to the wheels and thus, the system cannot function, resulting in a 'TPMS' light.
However, you do have a few options:
Option A - Ignore the light and just drive/check your pressure like you would before TPMS was made mandatory.
This is NOT recommended since the system is their for your safety, and should anything happen to you and/or
your car, you may end up at fault for driving with a system that is not functioning. Also, in many states you will
not pass inspection with this light on.
Option B - Buy new sensors and have them installed in your new wheels. This option will allow you to have a multiple sets of wheels
with the system intact. However, the car can only be programmed to recognize one set of sensors at a time. So, you will have to go to a
honda dealership and have the reprogram the system each time you change wheels. People have reported that the cost of this at the dealership
is roughly $100.
Option C - Have the stock TPMS sensor swapped into your new wheels. This option is sort of tricky, because not all wheels are shaped
the same on the inside. Our system has the sensors connect to the valve stem and the sensor must sit flush against the inside of the wheel.
If, due to the shape of your wheel, the sensor will not sit flush... you can create some kind of spacer that will allow the sensor to sit flush.
5. Ive heard that if my TPMS or Low Pressure light is on, I cannot turn VSA on/off. Is this true?
This seems to be the question that has caused the most confusion about the whole TPMS system.
Now, I have tested this numerous times in order to try and understand it as much as possible.
Thanks to tests by myself and other members, it seems as if the manual is NOT correct
when it describes how VSA is always enabled when either light is present.
Again... (on US models 08+), if either light (TPMS) or (!) is on... your VSA will still function as it normally does
6. I have a new set of wheels that I did not put the TPMS sensors in. But the TPMS light did not come on. What gives?
Dont fret... the light will come on eventually. Why there is a delay, I am not sure. The few times I have tested this it
will not turn on until you have driven roughly 40-50 miles.
7. I have a new set of wheels that I did not put the TPMS sensors in. I still have my stock wheels with the sensors
for the winter. Will the TPMS light go off when I put my stock wheels back on?
Yes, when you put on a set of wheels that has the registered sensors onto the vehicle, after a couple minutes of
driving the TPMS light will turn off.
61 - 80 of 395 Posts
i have verified the tpms/vsa function on other models outside of the civic, and yes you will not be able to disable vsa if the tire pressure light is on.. on NON-civics, like the accord or cr-v, tl, rl, pilot, element... and most of the civics, the si probablly has different parameters
is roughly $100.
Is that $100 for the sensors and the reprogramming or just the reprogramming?
F*ck...how much is it for the sensors?
roughly $30 each
The TPMS system is driving me nuts. I bought a set of new wheels recently and had the shop swap my stock sensors onto the new wheels. Unfortunately one of the stock sensors broke when the shop was installing my new wheels -__- So the shop had that sensor ordered via my car's VIN# and installed it onto my rims, but the TPMS light stayed on. I took it to the dealership and had them reprogram the light, and after try after try, they finally thought they fixed the problem with the light by disconnecting my aftermarket stereo and recalibrating the TPMS then. They stated that because I swapped the OEM radio with an aftermarket one the PCM (?) doesnt recognize it and thus when recalibrating the TPMS, the light will still stay on. After 3hrs at the dealership I thought the problem was fixed. I drove home no light everything was cool. Later that night though, I drove my car again and poof the light comes on! -__- I have NO idea what it could be. But I'm afraid if I tell the dealership about the problem they will charge me more money to fix it. Any car gurus have any clue what could be causing this problem?
My best guess would be that one or more of your sensors are faulty. Since the shop broke one, its easily possible that they damaged one or more of the others.
Man... so in the long run, it might be easier to use only one set of wheels, and have the tires re mounted/balanced, every season.
Does the dealership have to take your tires off, to calibrate a different set of TPMS sensors?
I dont beleive they do...
but the easiest thing to do is just ignore the light and use whatever wheels/tires you want
I'm looking at buying a set of Mugen GP off of a Mugen Si from someone. The GPs already have TMPS installed but if I put them on my car, will it recognize / recalibrate the new sensors or do I have to take apart my stock wheels and swap out the TPMS?
this is answered in the 1st post
is roughly $100.
Note: Buying new sensors and what you intend to do are the same thing... its a different set than what came with the car, and thus, will need to be programmed
Dang that really sucks. I guess I'll just have to put some work in and swap the TPMS sensors when I get the chance. How easy/difficult is it to change TPMS sensors? Is it like changing a valve stem?
That I do not know... I have not physically done that myself. Im sure someone on here can answer, though.
Changing TPMS sensors isn't that hard. Obviously, you need the tire changing machine and so forth. Actually installing the sensor on the wheel, you need an 11mm socket. Be extremely careful: if you apply to much torque to the nut when installing the sensor on the wheel, you WILL brake the TPMS sensor.
so basically just tighten to a snug fit. tire places like merchants should have plenty of experience with this right?
They should, but every now and then, they may get careless.
With the Honda TPMS sensor, when you get it right, you would hear a slight click or very faint pop which means you have it just about snug enough. Only a little more torque and it's good. But, seldomly, you may not hear it which is where you have to start going by feel, and it might break if you don't have the feel down.
Doesn't sound like a good idea, if you get into a wreck. I don't want to give insurance any reasons to deny my claim.
they could only deny your claim if they can prove that improper tire pressure caused the accident
^^ I appreciate the suggestions, but I'm just going to get some nice all seasons. I didn't buy a new car to have my dash lit up like a xmas tree, with warning lights.
"Nice" and "All-Season" don't go together if you're serious about performance as anyone that's experienced the difference between the two types of tires first-hand can tell you!
