1 - 19 of 19 Posts
I got my exhaust couple month ago, its a Greddy TiC and I got 2in welded on to it, because I have a sedan but about every two weeks my exhaust gasket keeps burning what could be the problem I am embaraced to go back to the shop again because I am there all the time for the same reason, also I have a dc race header. What could be the problem?
if you dont want to go back you can get this metallis aspestose/lead gasket mesh type paper that you can cut into whatevershap you eant... or just use a normal gasket and coat it in ultra copper. its made by permatex and can be found at all auto parts stores.
this will give you a good thermal brake... but the lead-type gasket peper is your best choice, its fiberouse and expensive. a place that makes gaskets and repairs starters/ bores blocks would have it...
its garranteed noit to burn, you can hold a torch to it and it wont so much as discolour...
whats the di of the pipe?, i can probable make you one out of the aspoestose lead and ship it to you... or just send you one thats close, the holes dont need to line up or anything...
they will be off of a volvo truck though, not like it matters....
the egr valves use the same size pipes as we do for exhaust... so what size is your pipe?
dude if you want help you need to reply to your own thread... ;)
heres one of the metalic gaskets i had laying around, its almost 2" id... idk if thats too small, did you have the k20 or r18 again i do have other ones..., but this one in particular i have a bunch of and if you want it its yours...
sorry about the cell phone cam pic, but it should be clear enough for what we need to see... also i know its not the same shape but it doesnt have to be...
Exhaust gaskets are metallic, and therefore shouldn't/can't burn. Are they using gaskets made of cork or something?
The other possibility is that they're not using silicon-based sealant, but some kinda flamable one.
Discussion Starter · #16 ·
hey, I think the pipe size is 2.50in or 2.75in, I dont know what the gasket is made out of, I have a k20. Let me know about the gasket and how much. Also I think I am suppose to have 3 holes not two. Thanks to everybody for a reply.
B-pipe to Cat gasket has three holes, the rest typically have two. You should always get the gasket size that matches your piping inner diameter. So if it uses 60mm (ie 2.36") piping, then use that size gasket.
Gaskets are about $3.50 and can be had in almost any auto parts store. I got mine by going to an Autozone and Pepboy.
1 - 19 of 19 Posts
