Warning
This mod has to be done before you put e85 into your fuel tank. it will corrode the contact pad very very quickly then you won't be able to solder on it. If you already ran e85 you will need to purchase a new fuel cage and they are a pretty penney.
step 1 push the tab down
step 2 push the float arm down and it should just pop out.
step 3 carefully rotate the plastic swivel down at the same time you need to guide the gold colored contact up and over.
step 4 the swivel will pop out, it is spring loaded.
the yellow wire is attached to a metal contact that is touching the contact pad on the "chip". doesn't matter how you remove it just don't damage the chip.
next cut the contact off the yellow wire and trim the insulation back.
now to remove the chip be extra careful, don't use any screwdrivers. just use your ole buger pickers and push the three tabs back and pop the chip out.
i'm not going to teach you how to solder but if you don't know how you should find someone who does. now isn't the time to learn.
you want to use regular elecronics solder. i used the stuff that came with my soldering iron that got from walmart. its not corroding at all, works perfect.
i tinned the exposed wire and soldered the ish to the contact pad. before you do that make sure the contact pad is nice and clean.
now carefully put it all back together exactly opposite of how you took it apart.
thats all there is to it, it will take you longer pulling the cage out of the car then doing this mod.
:cheerleader: yay now its time for some of that good stuff :badger::dancing::corona:
Thanks to COMplex here's the sender's pn Honda SKU: 17047-SNA-A30
