1 - 12 of 12 Posts
i was driving on the highway and my engine rpm dropped down to 3rpm.....i couldn't go faster then 30mph and the CEL and VSA came on.....i disco the battery and the lights came right back on....is there anything i can check before going to the dealership.....
Something of that magnitude should just be taken to dealer ASAP!!!!!! Don't touch it at all!!!
GL OP
I am assuming ur car is still under warranty tho..::don't touch it
Yea, i would deff take it to dealer if your under warranty, and deff! NO DOUBT OR QUESTION put stock OF ALL engine parts back on. Honda can turn you away even under warranty if they see non stock parts.
this happened to me before, well kinna
i couldnt go over 3,000 rpms in all gears lmfao
its prob jus your MAF, disconnect it blow into both female and male portions and reconnect until you hear the "click" and then try and drive it
and also get some MAF cleaner from an auto parts store if that dont work and if that dont work
go to dealer lol
good luck
Discussion Starter · #8 ·
i check the MAF and the connection to the throttle body....and still not running good......when you start it the idle goes up to 2k and never goes down.....when you rev it the idle acts like it wants to go down but goes back up to 2k.....and i also notice when you turn it off the engine idles down ruff
Not true at all. It must be proven the a specific and/or combination of aftermarket parts caused the given issue. This is like saying they wont warranty the car if it has a generic air filter in it.
dam dude... best of luck. I would buy the stock air box (15$ from honda I think) and a generic air filter just to avoid any issues at honda if for some reason its a large problem and they try to back out of your warenty (consider it a cheap insurance) then have it towed to your dealership for them to look at. It's what I'd do.
Discussion Starter · #12 ·
the dealer said it was a throttle body trouble code that put the car in safe mood.......they reset the ECU and the trouble code didnt come back........is this common if you have a CAI?
1 - 12 of 12 Posts
