1 - 20 of 29 Posts
Like the Title says, dose anyone have a Pinout of the Engine Controle Unit? AKA. the computer. The one in the engine bay with the three plugs, You know the one.(sorry, trying to avoid dumb questions)
I need to know for a project im working on. :D
Please, Pretty Please, With VETAK on top...
:badger:
Discussion Starter · #2 · (Edited)
Discussion Starter · #6 ·
Discussion Starter · #7 ·
BINGO!
the middle one.
Connector B (Grey):
34
GRN/YEL
VTS (ROCKER ARM OIL CONTROL SOLENOID)
Drives rocker arm oil control solenoid
At idle: about 0 V
Discussion Starter · #8 ·
edit: OOPS...
Its C(green)
23
BLU/WHT
VTC (VTC OIL CONTROL SOLENOID VALVE)
Drives VTC oil control solenoid valve
With ignition switch ON (II): about 0 V
Or bolth?
Discussion Starter · #12 ·
May i ask what youre working on?
VETAK of cores...
I want my interior to change colours from red to blue when the vtec soleniod engages.
Its all red right now :D
Discussion Starter · #16 · (Edited)
Guessing that the last one is C, and that they go from left to right, then the top left one is 1 and the bottom right pin is 44, that means that the one to the right of the clip is the one im after... Maybe? but no one that can tell me otherwise is online right now :(
green connector
#23
BLU/WHT
Discussion Starter · #18 ·
No, actually according to one of the treads, that would break the Board. You need to Scarface the casing in order to protect the PCB
https://goo.gl/h7GssA
oh wow .... hmm ok so we will not go that route ... there can only be four places that pin 1 can be on each plug so that means that there can only be 4 places where pin 23 can be
well times the 3 plugs you have to work with... but either way you are looking for a blue/white wire on the green plug, I should hope that there is only one like that
1 - 20 of 29 Posts
