1 - 1 of 1 Posts
Drop Engineering lug nuts are carefully crafted from AL7075-T6. T6 temper 7075 Aluminum is an aircraft quality alloy, boasting an impressive ultimate tensile strength of 74,000 - 78,000 psi (pound per square in) and minimum yield strength of 63,000 - 69,000 psi. This level of strength guarantees that the Drop lug nuts will hold up even under the most demanding racing conditions. Drop Engineering forges all of their lug nuts from AL7075 because it guarantees the greatest level of tolerance without any added weight.
Each lug nut is carefully crafted from an extruded aluminum billet. Drop Engineering utilizes CNC machinery to ensure the highest grade of precision quality during production. Stylish and durable, Drop Engineering lug nuts are an ideal upgrade for track or street drivers. These lug nuts are designed to function with Drop Engineering extended studs but will work on normal studs as well.
Specs:
Length: 50mm
Sold as a complete set of 20
Priced at $115 a set shipped in the 48 states! Alaska, Hawaii, Canada, or anywhere else in the world, let us know your address and we can ship USPS to you!
To order, just give us a call at (631)863-3820, or pm us your email address and we'll send over the invoice
Thanks!
1 - 1 of 1 Posts
