:yeahthat:hmm maybe a voltage regulator going out or simply the whole alternator. Are you pushing a lot of wattage in a stereo system or anything like that? How many miles does the car have? Does just the radio go off or do other things also reset like radar detector, dash lights, dome lights. Just a thought.
time for an upgrade :biggrin:yeah i have the NST overdrive alternator pulley, No Sound system just stock, and i also have a NRG ground wire system
Kind of a guess, but you should double check the NRG ground wire connections (6 wires?). If you see any corrosion or carbon buildup on either side of the wires, clean/sand it off. Carbon / corrosion could build up if the connection is not tigh which could cause some unintended behavior in some components, depending on how they are grounded.yeah i have the NST overdrive alternator pulley, No Sound system just stock, and i also have a NRG ground wire system
