221 - 240 of 261 Posts
At least someone answered. I asked the same questions awhile ago. Good to know you got an answer!
Thanks for this great DIY, it was awesome! Just a tip, add in to turn your wipers on so that they are perpendicular with the sides of the windshield, it helped a lot for me.
did mine today. i have to say.. extremely easy and turned out great!
more pics to come once all is installed.
Matched my valve cover to my brakes.
^thanks. im really impressed with how everything turned out.. the color changes alot in different light.. thats the general look of it unless it's in the sun.. then it really pops.
garage queen
Discussion Starter #236
****PLEASE DO NOT POST THESE PICTURES ANYWHERE ELSE****
I noticed the pictures for the previous DIY have been long gone. SO I thought I make a new one...
Tools:
- 10mm socket short and deep
- 12mm socket short and deep
- Whatever size ratchet you want use
- Extension
- Flat head screwdriver
1. Disconnect the negative battery terminal (blue).
2. Take the cowl off.
Reusing this picture (credit goes to whoever took it)
*Green: the 3 push clips. Carefully pry off with the flat head.
*Yellow: pull up carefully.
There are 6 clips that hold it down (red):
After you take off the 3 push clips earlier, you can look underneath and see the 6 clips. Two ways to go about it, either just pull up gently until they pop out or if you have tiny hands go underneath and pop them yourself.
*Blue: Just pull down and out. You can leave it hanging on the windshield or unplug the windshield washer hose and move it out of the way.
3. Remove the shield.
-There are five 10mm bolts and four 12mm bolts you need to remove before pulling the shield out.
Red = 10mm
Blue = 12mm
*Left side:
*Middle:
*Right side:
-Once those are removed, just wiggle it out.
4. Remove IM cover and spark plug cover. Both are 10mm.
-Once those two 10mm nuts (red) are removed on the IM, carefully pull up, might take some effort. Same for the spark plug cover (blue).
-Unclip the vacuum hose and set it aside (yellow).
5. Removing the valve cover.
-Look on the right side of the valve cover and you will see a mess of stuff. Remove the two 10mm bolts that are attached to the valve cover. Leave it hanging.
-Remove the two 10mm bolts (blue) holding down the ignition coil packs, unplug them, move them aside, then take out the coils.
-Remove the six 10mm bolts (red).
-Be sure to remove the chrome washers before pulling off the valve cover! Finally remove the oil dip stick, cap and finally pull off the valve cover.
Installation: Reverse uninstall steps :laughing: *note- when tightening the valve cover bolts/nuts, I suggest not to torque them. You will most likely snap the bolt or stud. Just nicely snug is good, not too loose not too tight.
This phrase could have saved me close to $1,000. Just make them snug people. :readtherules:
