This past weekend I worked on the install of my aftermarket radio into my si w/ premium sound. I spent more time researching to find the correct wiring to avoid not having my factory aux work properly or without adding another adapter cable.
So far everyone knows the HA13B cable from Scosche is good with the exception that the 20 pin connector is completely wrong. I have identified the correct pin configuration and it works flawlessly. Now you can have the factory aux port like it was intended.
Below is how the wires should be positioned.
This is the correct way for the Blue wire (amp remote on) and RCAs
Scosche HA13B by jfranknbeans, on Flickr
