1 - 16 of 16 Posts
Davori
· Registered
Discussion starter · #1 ·
I got tired of the dangling coiled SmartCord that came with my Escort radar detector and so I decided to hardwire it. I wanted to do it in a way that does not make any modifications to the car and not have to remove pieces of the interior/dash. Basically, what I did was mount the radar detector on the top of the windshield, to the left of the rear view mirror. Then ran the power cord across the headliner to the A-pillar. The cable then goes through the A-pillar into the place where the weather strip for the driver's door is set into the car body. It continues to run down the length of the door frame inside the interior trim plastic pieces and exits right next to the interior fuse box under the dash. The mute switch/light module that is part of the SmartCord is mounted to the bottom left of the dash. Power is taken from the #8 fuse in the interior fuse box and grounded to a metal bolt under the dash.
The Escort Direct Wire SmartCord.
The blue clip is for splicing into a 12v wire and is not needed. The grounding wire connector can be left as is, but the connector on the hot wire of the SmartCord needs to be cut off. That is because the hot wire will be attached to the Add-A-Circuit module.
Our Civic's interior fuse box uses these small fuses called "Low profile mini fuse." They are basically the same as regular mini fuses, just shorter.
A product called "Add-A-Circuit" made by Littelfuse works with mini fuses. There are two "Add-A-Circuit" models. One is for ATO sizes and the other is for mini fuses.
Add-A-Circuit for mini fuses.
Add-A-Circuit for ATO fuses (does not work in the Civic's interior fuse box).
The Add-A-Circuit kit comes with 4 fuses. The smallest one (3 amps) will work fine with the module since radar detectors uses less than 2 amps.
The Civic has a few unused fuse slots, so I decided to plug the radar detector into one of those instead of tapping a slot that is currently in use. I decided to use fuse slot #8 because that one is switched and is powered when the key is turned to the "on" position.
Some of the fuse slots are always powered and others turn on when the key is turned to the "on" mode. Only 1 unused fuse slot (#34) powers on in “accessory” mode.
Note: When using “on” position fuse slots like #8, the radar detector will show “Low Voltage” when starting the engine because of the current draw. If an “accessory” fuse slot is used, this will not happen because upon starting the engine, those circuits are turned off and then back on when the engine is running. I may decide to tap an existing “accessory” fuse slot if the low voltage situation starts to annoy me.
The connector on the hot line of the SmartCord has to be cut off and plugged into the Add-A-Circuit module's red wire. The grounding wire from the SmartCord is hooked up to a metal bolt attached to the car frame. There are 3 other wires already attached to this bolt, so it is a good place to hook up a ground. The wires are tie-wrapped to the side of the fuse box just to prevent the wires and fuse holder from swinging around when the car is moving.
Now, with the SmartCord's hot and ground lines hooked up, it's time to run the cord that goes into the radar detector. At this point, I disconnected the car's battery and waited 30 minutes to prevent complications with the side curtain airbag.
I pulled out the weather strip that seals the door to the frame when the door is shut. It was not necessary to pull out the whole thing. I started at the spot where it says “SRS Airbag.”
I took the other end of the SmartCord (the one with the phone jack) and slipped it inside the newly exposed trench.
Note: It is very important that the cord be routed behind the airbag—the long thing covered with white fabric—because you don’t want to block the airbag’s ability to deploy in the event of a collision.
The jack should come out right here.
I settled on an optimal spot for the radar detector and pulled enough cord through to the detector. When the amount of cord needed was reached, I pushed the cord under the front of the headliner. The headliner was a bit stiff. But with enough force, the headliner will pull back just enough to slip the cord inside.
Now I just tucked the cord into the trench that was behind the weather strip. This is near the bottom of the A-pillar.
The cord continues its journey inside the trench down the side of the door.
There is a neat little opening right next to the interior fuse box that the cord can exit the trench into the interior of the car.
With the weather strip pushed back into place, the excess wires are stuffed inside the little compartment above the hood release handle.
Since I didn’t want to drill/cut holes into the dash, I mounted the mute switch/light module onto a clip.
The module is clipped here. It’s not as clean as an in-dash installation, but from most positions inside the car, the wire can’t be easily seen.
Module finished and in place.
View of the module from the driver’s seat.
Again, there are cleaner in dash installation options, but this is probably one of the better options without removing pieces of the interior.
Discussion starter · #5 ·
How do you like the radar detector? I have always wanted one but never knew what make/model to buy, any suggestions?
I love having a radar detector. Although having one doesn't mean you can go speeding and not ever get caught. You have to learn to use it since it serves only as an early warning device.
Escort, Beltronics, and Valentine are the 3 biggest brands. Escort and Beltronics is kind of the same company, so you are left with only 2 major companies that makes the best detectors. My Escort detector is not the top of the line model, but it has served me well. It has already paid for itself on more than one occasion :wink:. I've heard Valentines are good too but don't have any personal experience and there is only 1 model, so not much of a choice. It comes down to personal preference. Do try to stay away from the cheap radar detectors though, their performance is usually sub par.
Discussion starter · #7 ·
got the passport 9500ix coming soon :), also made by Escort. Cannot wait!
Nice! That's the fancy top-of-the-line model. A little too high for my budget so I opted for the 8500 X50. The SmartCord that I use for my 8500 X50 also works on the 9500ix. I like the mute switch that comes with the SmartCord, it's handy even though wiring it is more work than just a single power cord from the power source to the detector.
Hi Davori and 8th gen folks. So i have my radar detector, tried to hardwire it and it did not work.
When i looked at your 2nd photo (fuse box photo) i noticed that the add-a-circuit has a fuse plugged into it as well (3 amps?).
Is that why it wasnt working? If so..why? noob at electrical stuff :/
Discussion starter · #13 ·
As Martin said, you need a fuse plugged into it in order to complete the circuit for it to work. You can use a multimeter and test the add-a-circuit for continuity to figure out how it works.
Man, I did everything just like you did. The only thing I did different was I used a 5 amp fuse and I don't have the mute button.. It's not working for me... I read over this 5 times and made sure I have everything right, and I do.. A shop tested my fuse panel and it has power so it's good.. I also bought 2 add-a-circuit and both of them don't work.. WHAT AM I DOING WRONG?
Were you able to figure your problem out? It seems I have run into the same problem and I can't seem to figure it out either.
one thing - if you have your add a circuit installed upside down (wire pointing up) you will need a fuse in both slots for it to function correctly. better to install it the "correct" way with the wire pointing down.
1 - 16 of 16 Posts
