1 - 20 of 437 Posts
DIY for having your OEM Fog Light come on with your Parking Lights. While having use of the Oem switch.
First remove the fog light fuse. #6.
Now locate the blue 6 pin connector on your fuse box. If you installed your fogs you remember this. you dont have to disconnect.
Now find the red/black wire on there. should be the first one on the top row. This will be your 12v source that will activate your relay with the parking lights.
Now tap that wire. heres a few pics of the, but there kind of f'ed up.
Now locate the connector on the back of your oem switch and tap the purple wire. This will be your negative feed to activate your relay.
Now pull down your relay box, and pull off the relay. This was a pain in the ass to get off that hook, but it comes off you just got to use some elbow. Heres a few pics of it. Notice how the wires are in a "T" shape. The top of the "T" the red/white wire is the 12v source that activates the relay and the blue wire is the negative wire that also activates the relay.
Now cut the wires at the top of the "T" leave some room to strip the wires.
And the wires striped.
Now crimp some ends on the wires that you taped earlier. I used red for the positive and blue for the negative.
Now crimp those to the relay box wires. Red to red/white and blue to blue
And thats it. put your relay back in and click it back in its place. and put your fuse back in clean up some wires and injoy.
Before
After
:vtec: :vtec: :vtec: :vtec: :vtec: :vtec: :vtec: :vtec: :vtec:
Purpul Plane 4ever!
nice!!! did you install the fog lamps? any different steps if the fog are already on there from factory?
yeah i installed them with help from NBP~FG2. im pretty sure that fogs dont come from factory, they just installed at the dealer.
Discussion Starter · #7 ·
thanks everybody. sorry if some of the pics are f'ed up. if you have any questions just hit me up. ill try and take some better pics tonight.
Nice job man. I never thought that relay was coming off. Now I just have to figure out what to use on my 07. but I think I just need to find the wire that activates the relay when I turn the fog light's on from the turn signal stalk.
P.S. I have JDM fog light BULBS. lol
Purpul Plane 4ever!
I will be doing this maybe next weekend. I finished the fog light retro yesterday, but its rainning today. I need a garage, lol
Ok so If I get foglights they wont come on with just my parking lights on?
Wich means they will only come on when headlightd turned on or is this just a conveniance thing?
2 questions about this:
1) Is the harness the same as a sedan? So will I be able to use these instructions and get the same results?
2) Do you still get the fog indicator on the dash?
Discussion Starter · #14 ·
im not sure about the sedan harness. and i do get the fog indicator on the dash, but only when the headlights are on. still working on gettin them to come on with the parking lights.
Discussion Starter · #15 ·
Xenin said:
interesting.
next time use the focus button (flower icon) on your digicam for taking close up shots like that.
sorry about teh shitty pics, ill take better ones, some time this week.
i actually want to do this right now...like right now!
let me get this straight:
red/black wire goes to red/white wire?
purple wire goes to blue wire?
just cut the red/black and purple wire and reroute them to the relay? or are the wires being spliced?
Discussion Starter · #17 ·
ok your right on where the wires go. please dont cut the red/black wire or the purple one. those get tapped into. but the blue and red/white wires are the ones gettin cut. i get off work at 3pm ill take better pics.
How come I never saw this thread? I had been asking this question since June of 2006!!! OMG, I gave up.....looks like I'll be outside looking at this on my lunch break!!!!
+rep!!! Thanks for the DIY
So the wires that we are tapping into...the red/black and purple. We still leave those connected and live, right?
1 - 20 of 437 Posts
