2007 Honda Civic Coupe
LED Replacement Guide
Now before I begin, I will start with what an LED is. The acronym stands for Light Emiting Diode. Basically a one way voltage is applied and you get light, without the heat, therefore more light per wattage as less is wasted in the form of heat. Also the life expectancy on most quality LEDs (not all!!!) is over 100,000 hours. That means years of use depending on use. Now over the life of the LED they will slowly dim, but never by a huge amount unless they are cheaply made.
IMPORTANT: There are many scams saying "1 Watt LED", in hopes people will buy it thinking it is an original 1 Watt Luxeon LED, but this is not the case. They are generally 6 leds on a single die, that consumes a total of 1 watts, but will not have anywhere near the same output. For and wattage over 1 watt, only Luxeon and Creon LEDs should be considered. (1,3,5 [and in my flashlight 6!!!] Watts)
I have tested out a few of these bulbs, and will be soon posting a DIY on custom fabrication for brighter applications. In the mean time you can buy replacements for these, and these are my recommendations
Area/bulb type Replacement Options (brightness scale 1-10)
Low beam headlamp DO NOT REPLACE WITH LEDs
9006 DO NOT REPLACE WITH LEDs
High beam headlamp DO NOT REPLACE WITH LEDs
9005 DO NOT REPLACE WITH LEDs
Parking light 3457 Use Red or white with sidefiring LEDs
Front turn signal 3457
Use amber or white with sidefiring LEDs
Rear turn signal ONLY USE the 13 or 18 SMT LED amber kit, for full
992 (7440A) brightness. MUST HAVE SIDE FIRING LEDS!
Tail light Now im not sure which is considered the "High stop" but that
7443 one must be replaced with a side firing LED red or white. The
others must be replaced with a combo of LEDs, preferably
Stop light a 13 or 18 SMT kit, Red or white should work. Red will work
7443 better.
Fog/Driving light DO NOT REPLACE WITH LEDs
H11-55W DO NOT REPLACE WITH LEDs
License plate For light amount purposes and legality, only use the
168 imitation 1Watt LED side firing in WHITE ONLY!!!
Do not attempt to use the small single LEDs
Back up light Any variation will work, for brighter ones, make sure a few
921 LEDs in the set are side firing so the reflector works
Rear sidemarker Same idea as the license plate lights. white or red only
168
Map light For both the map and dome lights, make sure you use either
DE3175 the 9LED festoon 31mm bulb, or the SMT LED festoon
31mm bulb. They will only work when plugged in one
Dome light direction. So swap if it wont light. Project underway for
DE3175 Creon 3watt LED festoon bulb, with DIY soon!
Trunk/Cargo area Currently a side firing 1W LED is the brightest. Project
2825 underway to create a 3 Watt Creon setup (95 lumens!)
Websites to search:
http://www.superbrightleds.com
http://www.ebay.com
Most other sites do not offer any good deals as of yet. But I will modify the doc and the post as I find promising sites.
Any questions on anything LED related please feel free to email me at [email protected]
7443 better.
168
Websites to search:
http://www.ebay.com
