161 - 180 of 192 Posts
Quick question, what size screws do you need for the MAF to bolt onto the intake? I got mine installed yesterday and last night my check engine light came on, I was going to reset the ECU today but when I looked I noticed one screw missing and the other one was loose and stripped. Any suggestions?
Take the good screw to an ACE hardware or somewhere similar and measure the size of the screw, then go to the nuts and use those to find the correct pitch. That's the way I usually figure it out.
I also used a cut open rubber hose when I installed mine. I also put some thermal heat wrap around the lower pipe where it could rub and put a clamp on it so that the metal from the clamp would rub if anything.
When I recently removed the CAI everything still looked good
i recently baught a cold air intake with a single pipe . ive seen tons of DIY's on the 2-peice pipe which seems pretty straight forward, can anyone help me out as to how the single one goes ? also, some DIY's i seen has only 2 hoses, i have 3 ? someone help ?
