DOSCLAIMER: I WILL NOT ACCEPT RESPONISBILITY FOR U FACKING UP UR CAR, THIS DIY IS WHAT I WAS TAUGHT AS A TRAINED TECH AT HONDA, DONT DO THE DIY IF U DONT FEEL COMFORTABLE ENOUGH WITH UR LACK OF TECH SKILLS TO DO IT RIGHT
TOOLS AND PARTS LIST
1. Flat head screw driver
2. replacement bulbs
3. beer
STEP 1
if replacing the drivers side bulb, turn the wheel to the right
STEP 2
take the flat head and remove the two pop clips that hold in the wheel lining
front two only
STEP 3
pull back the wheel well lining as illustrated in the pic below
now if u look in the wheel well u can see the bulb and have a clear path to stick ur hand in and pull it out
STEP 4
reach in and unplug the bulb, may be hard, but easier to unplug it first.
then turn the bulb counter clock wise bout 1/3 turn, till u feel it give
STEP 5
pull out the bad bulb and insert a new bulb, then plug the bulb back in and replace the wheel well lining back to normal, re insert the pop clips...follow this same process for the passanger side headlight.
3. beer
STEP 1
STEP 2
front two only
STEP 3
STEP 4
STEP 5
