1 - 14 of 14 Posts
i have a random tech cat on the way. do i need a defouler so i don't get a cel? i've read one is not needed but to those who have them should i get one?
ryanster01 said:
friend has one, no defouler, no CEL
yeah this is what i've been reading i am just worried about long term. if i put one on anyways would it mess anything up?
i have RT cat..and got a CEL after having it for a couple months. wont hurt adding a defouler. i have it on now and CEL is gone.
Jardiniboy said:
He doesn't have the defouler. And he's doing good w/ the high flow cat.
:yeahthat: The only problem that I have had is that the exhaust squeeks, It is the hanger. I reasearched around, and I guess a few people with the stock exhaust have the same problem. When you install it move the hanger around to see if it squeeks, mine does, but I have not had time to get under there to see how to fix it. It only squeeks under very light throttle at low rpm, and when starting out in first.
Purpul Plane 4ever!
You dont need a defouler. When installing make sure to twist the wires while you twist the sensor. Could possibly pull one of the wires out.
Discussion Starter #13
did you get the angled defouler or straight one?
1 - 14 of 14 Posts
