Proud owner of a manual 2008 Civic LX. Been my commuter for last 4-5 years. Has about 143k on the odometer. Owned since about 70k or so, don’t know of prior history. She burns less than 1 quart between changes. Doubt it’s ever had chain looked at.
I’ve done all the regular maintenance but over looked the timing chain problems. Had a 2004 Element for several years that needed a chain at around 140k, so I figure I’m probably due.
Anyways I was driving home yesterday and she started running rough, flashed the CEL and went to limp mode. It’s got a solid dead misfire for sure. Doesn’t sound terrible though, nothing banging, still have oil pressure. Had it towed home and scanned it with my basic iPhone app and Bluetooth dongle.
Got codes for cylinder 4 misfire and a catalyst inefficiency code. TBH I’ve had the p420 for about 1-2k miles, it would come and go, I had just gotten a new O2 sensor to replace this weekend.
So far I’ve throubleshot for spark and compression. Spark is good, compression was bad 60-70 psi on cylinder 4. #3 was 130-140 for reference.
I scoped the cylinder real quick and only had a chance to look at most of the piston and I think the intake valves. She’s looking pretty oily but in one piece, no signs of valve contact. I’ll try to get a better look at her tonight or later tomorrow.
Coolant seems clean and has not leaked.
The questions I have for you all:
Is there any chance that timing chain wear or skip could cause low compression misfire in only 1 cylinder?
Or am I looking at a new top and/or bottom end?
Can I tell if I bent a valve if a pull the valve cover?
Next step was to pull the valve cover and see if the timing skipped, but wanted to check with you all here before I got too involved in this thing. I’m somewhat mechanically inclined and plan to fix myself if I’m looking at a timing chain.
Thanks in advance for any help!
