1 - 19 of 19 Posts
I have a dcrh, what to I need to install it? Do I need a new gasket to go between header and catback? I've been told I need to wrap some things with heat resistant tape, what do I need to wrap, and what kind of tape is it? I want to put a catalytic converter on the header. Can one be welded directly on the header? Can the header be installed without the flexpipe, because there doesn't appear to be enough space to fit a cat? Where is the best place to buy a freeflow cat, the best i've found is 70 for a vibrant cat. Thanks for all the help.
I bought the BCRH because of previous issues DC had with the flexpipe on their RH's on the EP3 & DC5. I doubt you will have any problems not running a flexpipe.
What tape? The gasket that is probably being mentioned is the three hole catalytic exhaust flange gasket.
Discussion Starter · #8 ·
The person who gave me the header told me that you have to wrap some of your wiring thats near the header with heat resistant tape, because when you install the header you have to remove the factory heat shield.
you might see some gains if you add a cat. get the non fouler to get rid of the check engine light and find you a place to hook you up on your inspections forget about adding a cat. and it might still be possible to crack your header without a flex pipe
I've had RH's on my last two Si's without issues with the wiring. I guess if you want to then go ahead but I didn't add any additional heat wrapping.
Hey did u ever find out what size hfc did u need for the DCRH? And not having DC sports crappy flexpipe is butter, my 03' Accord's DC Sports flexpipe cracked in 3 months, so I had my local exhaust shop weld in a straight pipe had no problems. Honda does a great job with giving the exhaust system room to move back and forth. Also, if California's emission are some of the strictist in America and they need at least a 400 cell cat... I should be able to pass TN's emission with a 300 cell right?
i just picked up a dcrh for $125 and i pulled my tape out to measure the pipe and it said that the od of the pipe was a solid 2in right after the flex and the id of the pipe was 1 7/8 what the heck?
Discussion Starter · #19 ·
What size cat should I get, the collector is a little under 2 inches, so should I get a 2" cat or should I get a 2.25" and replace the piping and flange after the cat so it exits at 2.25"? Thanks for the help. I figure the dcrh should be higher flow than stock, and a high flow cat should flow better than stock, so I am thinking should see some gains.
1 - 19 of 19 Posts
