Great post, ill add also with cams need a ported RBC or port matched 72mm RRC.
Great post, ill add also with cams need a ported RBC or port matched 72mm RRC.Vit, Let me answer it for you.
Gentlemen the DC2.2 cams Will make more power EVERYWHERE over stock cam because of the duration of the cam. These cams peak at 9200-9500RPM ( that doesnt mean to rev that high.) the Skunk2 Stage 1 cam is a great cam aswell but the peak point of that is 8400-8600 depending on the health of the engine and your mods. The main part of cams is you NEED a flowing header. No replica bullcrap like DC,Strup,PLM. its either a gopower header if you can find one or a skunk2 alpha/megapower
No, Its not required but its suggested. i personally rev my stock pump to 8800. but im looking to get a RRC oil pump here soon, which is the same thing as a A2 pump just a direct bolt onWould u say different oil pump is a requirement for these?
no but you should if you're revving over 8600Would u say different oil pump is a requirement for these?
DONE, thanks for the heads up.drag cartel is having a black friday sale on these + supertech valvesprings/retainers for like $1250
im thinking these are going to be my next mod as im currently making 223whp with hybrid racing intake, skunk2 header and full race exhaustWhat do you need to know?
nice, i've installed cams on a b18 before but haven't had the chance to experience with the k20 yet so im gonna have them installed by a shop since im also getting the supertech valve springs with themthese cams pick up 15-20hp. you can tell for sure that the power last longer then stock cams. you pick up low end tq and of course top end.
I would suggest getting the RRC oil pump. since it involves zero cutting and i found out from autofair honda that it has a lower pick up point for the oil which is better.nice, i've installed cams on a b18 before but haven't had the chance to experience with the k20 yet so im gonna have them installed by a shop since im also getting the supertech valve springs with them
i wanted to get my manifold ported and port matched to a j37 throttle body along with the type-s oil pump conversion but those will have to wait
good to know, thanks !I would suggest getting the RRC oil pump. since it involves zero cutting and i found out from autofair honda that it has a lower pick up point for the oil which is better.
