1 - 9 of 9 Posts
ok i've put about 15hun. miles on my ct engineering supercharger and sometimes at about 3200 rpm it seems to sputter like its leaning out or somthing idk and i'm 95% sure i crushed the fpr correctly any ideas guys ?
Mine does it to but only when I am in 6th gear. I was told that it is normal because of the reflash. I posted a question like this a while back and it seems like alot of people have the same problem but if you give it some more or less it will stop.
I've experienced the same thing. Just as long as your at a cruising speed on the highway at about 3K rpms you should be fine. Usually when you're accelerating while in 6th gear (between 65-70 MPH) you'll get that little jerk because of the VTEC window. I notice it when I'm driving around 70 MPH and if you look, your RPMs should be right around 3K rpms.
1 - 9 of 9 Posts
