1 - 10 of 10 Posts
I bought one off of a 8th civic member yesterday used. Installing it wasn't too bad, but that blue cap is a pain in the ass.
Now that I am diving with it, I notice a somewhat shorter shift, but I also notice that gears 2, 4, 6 and Reverse all seem more notchy and rough than usual. Everything seems to take a bit more effort to shift, which I like. Much more solid feeling. Just wondering about the notchyness. Is that normal? Almost seems like it is rubbing, or bumping against something.
It is rubbing. shouldnt be a problem. itll rub through the plastic eventually and itlll be smoother. My car had that.
the cap got scratched up a bit, but nothing too bad.
The short shifter sits in the cap, and rotates within the cap, so any scratches on the outside of the cap shouldn't make a difference.
Why did they design a ss that rubs? Wouldn't that be something they would have seen in the design phase?
I'll have to make sure it is on there tight.
Si-Onara
make sure its pushed all the way up. mine has never rubbed:thumb:
I have heard that the 09 Si's are different not sure if this claim is true or not though.. So guy was selling his based on this asumption but i cannot claify the validity of it.
Discussion Starter · #7 ·
well, it doesn't rub much anymore, just drove it around a bit. Noticed it smoothing out a bit as I drove. Opened it up to look and see what the deal was, and it had rubbed a nice grove in the shifter housing.
problem fixed...kinda. It is on there as good as it can be. Not sure why it was rubbing, but I guess it isn't a problem anymore.
i'm sure you have it on all the way. they just don't fit properly without some "trimming" as they say. i have an 09 si and i just tried to install a s2 shift adapter and it's not even close to fitting. i don't know why the 09's are so much different, but i would've had to shave a lot off the shift base to make it work. and i'm not going to hack up my car because people can't make a properly designed piece. just my thoughts.
If I were you I'd cut/trim the black plastic off alittle to get into those gears without rubbing it. I had to or else those gears you mentions wouldn't even go in. A little customize should be needed to get it to work correctly. Some models don't need to, my model needed to. It is an aftermarket part.
1 - 10 of 10 Posts
